Advice to get into the mid 11's
Wondering what more it might take to get to mid 11's so far what i have is :
rebuilt motor with ls6 oil pump, ls2 timing chain, stock internals, port & polished 241 heads, aftermarket clutch, bmr adj torque arm, bmr lca's, slp 3pt subframe connectors, and eibach sportline springs. Im pretty sure im not there yet, so i understand but be honest. by the way its 2000 camaro ss m6 stock body weight. thanks.
All I saw is what you listed in my first reply.
Not enough to change. Will you see an increase? Sure.. It is up to you whether the 5hp is worth the hassle/cost.
depending on the wheel tire combo you could go as low as 4.30 or as high as 3.90 but I'd stay in that range(seen both work). You def. need atleast an ls6 intake but other than that you should be in the 11s. It really don't take much with these cars if you can drive..that being the key as well as getting out of the hole
The mac mids are more than fine. They perform very well on these cars. I actually know a guy who went from mac mids to LT's and lost a little at the track. A friend of mine with mac mids and 4.10's went 12.30 in an auto on a stock stall. My point is, they are more than fine.
