Single Digit Club - First time out with new build ran 9.90
jsds500
11-10-2009, 07:10 PM
Just got car running. Its a 2000 T/A APS Twin Turbo with a 440 lsx block with ls7 heads/intake. No cage yet so only got 1 run. Went 9.90@ 132, Tune was off and it stopped pulling @ 6400, about the last 100' feet or so. Didn't use the trans brake and left @ 2000rpm. It still has a little left in it. Only running 9 lbs, hope to run 15 next year when I get boost controller installed.
Mark98SS
11-12-2009, 06:02 PM
Awsome, prolly has a lot left in it
Mark98SS
11-12-2009, 06:05 PM
Actually the 1/8th mph !!!!!!!
robert miller
11-14-2009, 07:34 PM
Great run man for 1st time out and with the low boost and no t/brake on the car. What was the 60ft time.:cool::cool:
jsds500
11-18-2009, 05:31 PM
1.557 60 ft. I left @ 2000 rpm, should have left higher but still trying to get used to the car.
dkbykesdk
11-22-2009, 10:32 PM
thats badass. i miss this car so much gad u got it done. u gotta see the mustang i got with a ls motor in it
jsds500
11-25-2009, 08:42 PM
Yeah got alot of work this winter, cage, mini tubs and gears. If you get up this way we could run at Lapeer one day.
1320 HUSTLER
11-26-2009, 12:59 AM
Congrats man! Things happen fast in the 9 second world!
TJ
11-28-2009, 11:55 AM
117mph will go 5's in the 1/8 mile.
get the short time down and youll be deep in the 9's.
Bill00Formula
11-28-2009, 12:32 PM
yeah, I was thinking the 132 trap wasn't any better than a good n/a stroker motor but then I saw the 8th mile mph and that was really good. Even at 9 lbs, seems to have a lot more potential.
jsds500
11-28-2009, 07:13 PM
Yeah I got out of it early, once i get some bugs worked out and get after it a little harder on the line my times should improve.
JL ws-6
01-06-2010, 07:35 AM
That 1/8th mph is good for about a 9.2 when you get it sorted out.
MY99TAWS6
01-23-2010, 04:03 PM
Can I get a complete suspension mod list on the car. Very nice times of course with tons of potential left.
jsds500
01-24-2010, 04:55 PM
At the time it had bmr k member,tubular control arms, upper and lower. QA1 single adjustable coil over shocks up front. Rear BMR torque arm, lower control arms, control arm relocation brackets and stock shocks. I am in the process of putting in mini tubs, QA1 single adjustable, adjustable control arms, and springs with adjusters
