A few questions on my build...6.0 swap..stock bottom end lq9??
Old 11-11-2009, 06:50 AM
mean94lt1's Avatar
Default A few questions on my build...6.0 swap..stock bottom end lq9??
ok so im oicking up a lq9 its going to have:
lingenfelter cnc ported 243 heads with 2.02/1.57 valves
ported ls6 intake
bbk 85mm tb
meziere ewp
cloyes adj timing set
either a ms4 or a custom grind cam unsure yet
i have comp 921 valve springs
comp hi tec hardened pushrods...will these work in the lq9??
also will the lifters out of my ls1 work in this motor they only have 40k on them?
what all sensors will i have to use off the 6.0 for the swap in my f body? its a 01 z
the ls1 motor that is currently in the car is out of an 04 gto
Old 11-12-2009, 03:22 PM
mean94lt1's Avatar
noone??
Old 11-12-2009, 05:04 PM
outkast6991's Avatar
pr length needs measured to be right. lifters will work and all ls1 sensors will transfer over. if this isn't a 24x tooth deal you'll need an adapter to run the stock computer with a 58x wheel
