? -- problems with Turn Signals
??? - Problem with Turn Signals..
I have a problem with my left turn signals, they will not work when I activate them. I have replaced all the bulbs work and I still get nothing. The arking lights work when I use the switch but the left drl does not. The hazards work but turn does not. Any help would be appreciated.
Replace the flasher. I had this same problem about a month ago. The flasher only cost about 3 dollars. The flasher is underneath the steering column by where your knees go.
Ungrounded Moderator
