question about rings for a blower set up
Hey guys I have to get new rings now that I pulled my motor back apart again. This time I am installing a procharger d1 at 10psi and my machinest needs to know what rings I am going to use and what stones to use on the cylinders to make sure everything works perfect. Any ideas?
I recommend running the Akerly and Childs Xtream rings you should run an HTD top ring. They are some of the best rings you can buy and they don't cost that much. I would finish your cylinders with a 818 stone or 400 girt.
