What throttle cable when removing cruise?
Old 11-11-2009, 09:30 PM
sheikss's Avatar
Default What throttle cable when removing cruise?
Got a 2000 camaro and was wondering what throttle cable you guys use when you remove the cruise control module.
Old 11-14-2009, 02:29 PM
Mike454SS's Avatar
Do you mean when you remove the traction control? My car (also a 2000 Z28) has no traction control, so the throttle cable goes directly from the pedal to the throttle body, and then a seperate cable that goes from the cruise box to the throttle body. Cars with traction control have longer cables that both go to the traction control box, then a third that goes from it to the TB.
So that said...if thats what you mean, just get a new GM throttle cable for a 2000 Z28 without traction control.
Quick Reply: What throttle cable when removing cruise?
