current time (11.66) wanting 11.30's??
ok guys i have 2000 camaro. i have ran the best being a 11.66 at 117 with the DA at 1950 with a unknown 60' because the 60' didnt come up but it has seen 1.63 with a slower time. here are my my current modifications done to the car.
stock 347 bottom end
410's
LT's
circle D 4c(3600ish)
prc 5.3 heads
231/234 Tsp cam
stock intake
UD pulley
torque Arm
lca's
what other modifications do you think i can use to get this car in the 11.30's constistently on motor? i already have nitrous on the car but i want 11.30's NA.
410's
LT's
prc 5.3 heads
231/234 Tsp cam
stock intake
UD pulley
torque Arm
lca's
the car is full wheight and running a 27/10.5 et street with about 15psi and it spun cause it left pretty hard.nothing has ben removed except for me having convo pros all the way around... what about a fast 92? any worthy gains over a ls6
ive tried to reduce timing by the amount of knock i have but it still does it so im gonna try some different things with the tune on friday and see what happens.
im going to try out a fast 92 since i have one on myy other car and see how that works out. 2-3 tenths possible with a fast if its hurting me?
i got a PB last night with still a little bit of knock due to my sensors being sensitive.
60' 1.61
1/8 7.405
1/4 11.61
MPH 117.28
These Et streets are not cutting it for me so im looking for a drag radial because i know they hook much better!!
To do list
Drop some wheight
Fast or Ls6
different tire
loosen up the converter. im looking for 1.4 60's
possible 10's??
