Boost limits of mildly built 5.3
Old 11-12-2009, 09:07 AM
S13LSx's Avatar
Default Boost limits of mildly built 5.3
I am starting my S13 5.3L turbo build and wondering what the boost limits will be and what is the failure mode when the LSx fail under boost.
5.3 with 9.0-1 CR forged slugs
oem ported heads
arp rod bolts and head studs(maybe 1/2" studs if I needed)
MLS head gaskets
MS3 cam kit from TSP with dual springs
truck manis
Holset 72mm HX55 for now(BW S475 or larger next summer)
glide w/3600 vigilante
Would like to start with a .6 bar spring putting it at about 8psi at the manifold and go from there. I have been told that 15-16psi on race fuel is about all I should ever push through this setup. I know that will be more than enough in the >3000lb chassis but I was wondering with the lower compression what limits the LSx on boost. Head clinch area, etc???? I will need a little more boost out of the Holset to make the power I would with a bigger turbo.
Please remember that I come from the world of turbo 4cyl where it takes 20psi to make 400whp. I'm sure there will be a learning curve.
Old 11-12-2009, 02:03 PM
extremetoy's Avatar
im making 15psi through a stock 5.3l shortblock with patriot stg 2 317 heads, ls6 intake with a tc 76...
where did you get the forged pistons for your 5.3l?
Old 11-12-2009, 02:07 PM
XtremeDime's Avatar
15 psi on stock internals? nice!
Old 11-12-2009, 02:12 PM
S13LSx's Avatar
haven't got them yet. I was assuming they were available??
Old 11-12-2009, 03:10 PM
c0ncEpT's Avatar
MS3 seems like a bad choice. Guys don't use them in there turbo LS1's for a reason. Let alone a 5.3 if it would even clear.
Old 11-12-2009, 05:36 PM
MUSTANGBRKR02's Avatar
Less cam with smaller motor and a more boost friendly would be a good choice.
Old 11-12-2009, 06:33 PM
extremetoy's Avatar
i guess wiesco makes an off the shelf model.. custom one im sure are avail. as well
http://www.texas-speed.com/SHOP/item...d=988&catid=38
Old 11-13-2009, 01:56 AM
9 Second Truck Club
stock48's Avatar
oem ported heads
MLS head gaskets
truck manis
Unless your running the 05 up LS2 style rods I think you are wasting your time changing the pistons. The rods are the weak link.
Old 11-13-2009, 02:49 AM
El_Diablo's Avatar
It's not the best choice but it will work if he's already got the cam and on a budget. It'll bleed some boost but that's not necessarily a bad thing for his engine.
Old 11-14-2009, 10:17 AM
TheFallen's Avatar
i run a 230/236 in a 4.8 and i dont see to have any issues make good power, over 700rwhp
Quick Reply: Boost limits of mildly built 5.3
