will I need bigger injectors for ported heads?
Old 11-14-2009, 09:27 AM
flintwrench69's Avatar
Default will I need bigger injectors for ported heads?
I will be installing a set of trickflow 215s, will my stock injectors be able to keep up or will I need to upgrade them?
Old 11-14-2009, 09:52 AM
teke184's Avatar
most likely.
i know i was at just over 100% duty cycle with 408rwhp.
Old 11-14-2009, 11:11 AM
Intercooler2's Avatar
I did 42's in mine when I did my top half. For $200 do it once on a tune and forget it.
Old 11-14-2009, 11:37 AM
02*C5's Avatar
depends on the hp also. You never want your injectors to be running higher than 80% duty cycle and they pretty much go static at 92% of duty cycle. Look at the application how much hp you are going to be putting out and then choose correctly.
Here you go it helps in choosing an injector for hp needs;
http://www.injector.com/injectorselection.php
Old 11-14-2009, 02:21 PM
Yea I think thats what I will do, just get some 42s. Thanks guys.
Quick Reply: will I need bigger injectors for ported heads?
