Truck manifolds WITHOUT moving alternator. =)
Cut the flanges off and welded vbands inside and out and it its going to allow me to keep the alt. in the stock spot and run these manifolds. (this sames me so much aggrivation) I cut the little tab off the alternator just for a little extra clearance.My friend does my welding and according to him he has to go through a certain process when welding mild steel(only) to cast iron. He did a set of manifolds for a turbo'd LS1 nissan 240 last year and they havent cracked yet. Also, my manifolds will have no weight on them since im mounting the turbo to the side of the car and running solid mounts(going to use some flex in the cross over piping.)
