super charger location w/Fbody accessories
Old 11-14-2009, 07:39 PM
81cuttysupreme's Avatar
Default super charger location w/Fbody accessories
i'm in the process of swapping an Fbody set up into a Gbody car. I have the Fbody LS1 with accessories in the original locations. i want to run a procharger, but would like to mount it up high, similar to the location i see on the GTO's. Is there brackets and belts already set up to do this? i thought GTO LS1 accessories were the same as F body, true? So will it be just as easy to mount the procharger up high on the driver side, near the ps pump?
Old 11-15-2009, 03:28 AM
DeltaT's Avatar
Also check at maliburacing.com, they have all sort of g-body folks over there, plenty of LS swaps.
Jim
Old 11-15-2009, 07:52 AM
EPP
EPP's Avatar
http://www.exoticperformanceplus.com...html?item=1795 Bob
