NGK TR55 vs TR6's ?
Old 11-15-2009, 09:47 AM
alank1953's Avatar
Default NGK TR55 vs TR6's ?
Anyone have any input as to why the colder TR6's should benefit over stock replacement TR55's. I'm running stock heads & cam, ls6 intake, 85mm BBK TB, Jet hot long tubes, LS1 edit, MSD coils & wires, 3000 Vigilante, shift kit, 3.73 gears and suspension stuff. Runs 12.30's at 110.00. Developed knock sensor code and misfire ( don't wash your ls1 engines with water guys ) so had to pull the manifold, front KS rusty and corroded !
Long story, but looking for the misfire, my tuner put TR6's in it and I wanna go back to the hotter plugs..............Any thoughts?
Thanks
Old 11-15-2009, 10:27 AM
KCFormula's Avatar
If your tuner knows the MSD coils well he could have optimized the dwell tables for the TR6s. Unlikely but possible.
Old 11-15-2009, 10:38 AM
alank1953's Avatar
Good thought, but I didn't have the MSD's on when I did the edit, one of the stock coils took a dump after the tune and I replaced them all with the MSD's.
Old 11-15-2009, 10:40 AM
99blancoSS's Avatar
colder plug will foul quicker
Old 11-15-2009, 10:50 AM
01ssreda4's Avatar
^^ I agree
tr-55=NA
tr-6=spray
generally speaking of course
Old 11-15-2009, 03:21 PM
alank1953's Avatar
Originally Posted by 01ssreda4
^^ I agree
tr-55=NA
tr-6=spray
Thank you All !
Old 11-15-2009, 10:58 PM
LT1T/A's Avatar
^^ I agree
tr-55=NA
tr-6=spray
Does this hold true w/ mild H/C setups as well? The car in question will have its 806's ported soon on top of a 219/230 607/.604 117 lsa cam.
Old 11-16-2009, 01:17 AM
c0ncEpT's Avatar
A very loose rule of thumb is for ever 100hp you add over stock you should go 1 heat range colder with the plug. Thats a very loose rule and can differ with every application.
Old 11-16-2009, 09:36 PM
MJs1FastSS's Avatar
maybe it already was impiled but why did you/he install the tr6s?
Old 11-17-2009, 09:40 AM
Skidog5150's Avatar
^^ I agree
tr-55=NA
tr-6=spray
I agree, that's the general rule. I've heard of going to the TR55IX which are the irridiums but not the TR6's.
Old 11-17-2009, 07:00 PM
alank1953's Avatar
My tuner installed them when he did the LS1 edit, I don't know why, I've replaced them with TR55GP's
Old 11-17-2009, 07:38 PM
Skidog5150's Avatar
What's the difference beween the regular TR55's and the GP's?
Old 11-17-2009, 07:57 PM
alank1953's Avatar
GP's are Platinum, for only a buck more than the regular 55's
Old 11-17-2009, 09:54 PM
Skidog5150's Avatar
Gotch ya. Thanks..
Quick Reply: NGK TR55 vs TR6's ?
