New LS1 Owners - Newbie Tech - what to get next????
0331gunner
11-15-2009, 07:38 PM
ok i got a 99 z28 ls1 with the 6 speed with 70,000 miles on her. I want more power. I got a cam (comp cam, xtreme energy in it. A 160'thermostat. im putting a set of pacesetter headers on it with no egr and a cutout after the y pipe (its a off road Y pipe). it has a borla cat back exhaust on it that will stay. I am looking for a ls6 intake for it and a slp lid but the lid has 98-99 then 00-02 so idk what one i need to get??? what else should i get for it??????
98_Formula
11-15-2009, 08:14 PM
ported polished throttle body. underdrive pulley.... if u got money to burn - electric water pump that should cover the bolt ons. could put some 4.10 gears in.
LS1_Sean
11-15-2009, 09:01 PM
Dr's and suspension. what are you goals with the car?
badss_02
11-15-2009, 09:05 PM
Suspension first my friend... I've learned that the hard way, its not so bad with an a4 but since you opted for the six speed you also opted to break easy... I would decide what gears you want to go with and do a built rear to start things off... Then supporting goodies... LCA's, SFC's, Body mount adjustable torque arm w/ driveshaft saftey loop, and steel drive shaft. Then if you want to throw more power at it, do an under drive, set of heads, all your free mods, and a good tune... If you are still not happy, buy some dope for it! Your cutout will not be good for any power most likely. I know a few guys, including myself, that have actually lost power with the cutout open.
badss_02
And definitely a clutch if you haven't already done one!
Dabom75
11-16-2009, 12:25 AM
If you throwing a cam in it I would suggest getting some better flowing heads to take advantage of the cam better.
thewholefnshow1
11-16-2009, 02:35 AM
Yes I'm with the guy above, get some better heads, port and polished throttle body and throttle body bypass. An also the clutch cause with cam and all the other work the stock clutch don't like those.
0331gunner
11-16-2009, 10:20 PM
My goals are to run in the 10's and maybe do a wheelie. Beat my 77 vette that my dad built the engine for. the 77 has a 383 stroker. he says its putting out just under 600hp but he has not had it dyno. I had mine done and he said it was only 294 rwhp with the cam in it.
homerunhtr21
11-16-2009, 11:26 PM
Factory headers, factory lid, ls1 intake? All of those should be addressed before a cam swap. To run 10's your going to need alot more power than you have right now. Do full suspension, head/cam, and some tires if thats what your going for. Or just buy a spray kit and throw a 150 shot at it after bolt ons/cam/basic mods.
b.t.w that is a low dyno number if you already have a cam in it especially if your an M6. Most dyno over 300 stock.
badss_02
11-17-2009, 10:11 AM
Having a cam in your car with all the supporting goodies still being stock probably made you loose power...
SOMbitch
11-17-2009, 08:13 PM
So what does he run??? That is key. I started out in Gen I stuff so I don't even want to get started but 600hp is unlikely (but not impossible with enough $$). I would bet though a good H/C/I bolton combo for you would get him easily. If he runs pump gas and a hydraulic cam on that car it is mild. Also ask him what heads he runs. If they are OEM they are not conducive to big HP like that even when ported....
77 vettes were low compression smog motors and made like 180fwhp stock and the L82 like 220 IIRC. So get all the particulars and report back...
laosraccoon
11-17-2009, 08:40 PM
Nitrous is always good for the lsx motor :)
badss_02
11-18-2009, 01:38 PM
fwhp??? Im pretty sure all vettes were always rw...
Unertl42
11-18-2009, 04:26 PM
heads
lexva_58
11-18-2009, 04:46 PM
nitrous!!!!!!!!!!!!!!!!!
87gnx
11-18-2009, 04:50 PM
Fly Wheel Horse Power, which was pretty close for that year Vette.
badss_02
11-18-2009, 06:05 PM
Facepalm...
0331gunner
11-20-2009, 05:32 PM
he runs 93 with a octane booster.edelbrock performer heads and a edelbrock hydraulic roller cam 580. headers idk but there not oem. he has never ran it on the strip. there was about 10 grand doped into this 383. this is the car.
http://www.ls1tech.com/forums/album.php?albumid=12005&pictureid=31437
COPO9560
11-20-2009, 06:20 PM
Not a bad build for a street 383 but he would need a big shot of nitrous to get anywhere near 600 hp with this engine.
0331gunner
11-20-2009, 06:36 PM
i think that's what he thanks he has with the parts he used. no dyno has been done
00fastta
11-21-2009, 11:11 AM
You wanna get into tens you say?
Ok I hope you have money because this isn't cheap
tfs245 heads
ford 9 in with 4.33 gears
monster stage 3 clutch
nice camshaft...250/250 @ .000 235/235 @.050 w/ .600in lift
fast 92 w/ supporting tb
stickies
underdrive pulley
Thats everything that I can think of right now...that should allow you to easily beat him, but to make a better reference you need to know what his car can run on the strip.
metalmechanic
11-24-2009, 01:09 AM
if you dont already, you should consider everything in my SIG. Susp/chassis
99FormulaM6r
11-24-2009, 01:35 AM
Heads/lid/manifold
Suspension obviously also, but if you're looking for power you need something to back up your cam
