e85 turbo guys, need help.
Old 11-15-2009, 10:19 PM
needaz28's Avatar
Default e85 turbo guys, need help.
so we tried tunning for e85 and sd today. got the fueling about dialed in, a/f is about 11.5 or so, but now it's blowing out spark. I'm running tr6's gapped to .032. what are you guys running for plugs and gaps?
Old 11-15-2009, 10:29 PM
jason02Z's Avatar
tr6's should be fine but a/f is way to rich for e85. 11.5 is good for gas, what do you run for timing, try somewhere around 8.5
Old 11-15-2009, 10:55 PM
z28boysteve's Avatar
What the last guy said except 11.1 is way too LEAN for E85, go look up the stochiometic burn rate the Ethanol, or E85 as you need to burn it around 7:1 or something ... 11:1 your not spraying nearly enough in there! and if your boosted, hell I run about an .018 plug gap to make sure that sob fires.
Old 11-16-2009, 12:06 AM
shoemike's Avatar
E85 stoichiometric 9.765:1
Old 11-16-2009, 12:15 AM
needaz28's Avatar
we had it at about 16* timing. i'm going to get some new tr6's and gap them way down, I was thinking .020-.024 gap. I'll try .02 and see what happens. I'm loosing fuel presure right now. I have 2 255 pumps, I have a 3rd pump here and I'm going to start on my custom top hat monday. (I'm a aerospace machinist) I'll once we get the spark problem figured out I'll talk to my tuner and get it down to where it need to be.
Old 11-16-2009, 12:24 AM
black98ws6ta's Avatar
There should not be a reason you are "blowning out spark" I have used tr6's to 1000 rwhp at .030, and currently using them at .030 on my 800rwhp stock motor on e85.
Old 11-16-2009, 10:47 AM
7 Second Club
NicD's Avatar
I am assuming your are still using a gasoline a/f reading which puts that 11.5 at an acceptable WOT reading for E85 although I prefer closer to a high 10/low 11. If you are blowing out the spark maybe gap down to .028 and see if it's any better.
Old 11-16-2009, 10:55 AM
needaz28's Avatar
thanks nic, I'll pass that on to mike. yeah, were using the wideband that I had set-up for 91. sorry I should have stated that.
Old 11-16-2009, 12:31 PM
shoemike's Avatar
With E85 EQ1 being 9.7AFR?
Excuse my ignorance,
but if 9.7AFR = EQ1 for E85 then high 10/low 11 would be lean @ WOT.
In the flex fuel OS' EQ1 moves with Ethanol%
but PE EQ stays the same.
Example:
0% Ethanol EQ1=14.63AFR
0% Ethanol PE EQ 1.17=12.5AFR
E85 EQ1=9.7AFR
E85 PE EQ1.17=8.3AFR
Old 11-16-2009, 01:00 PM
7 Second Club
NicD's Avatar
Example:
E85 EQ1=9.7AFR
Assuming that the wideband is still setup for reading a gasoline AFR then it would be correct. If it was setup to display ethanol AFRs then what I said would be wrong. All wide bands read lambda and then convert to the fuel type AFR for display. The Lambda measurements for E85 compared to regular gasoline are fairly close so if you are referencing a gasoline AFR wideband that's what I would shoot for.
Old 11-16-2009, 03:28 PM
Zombie's Avatar
This is why people should work in lambda vs AFR, it eliminates the confusion.
I tune to 0.75 lambada on E85 which would read as 11.0:1 AFR on a gasoline wideband. Max rich power on E85 is 0.71 Lambda.
FWIW, I gap to .025 on my plugs.
Old 11-16-2009, 03:48 PM
7 Second Club
NicD's Avatar
I don't see the confusion in just leaving your wideband alone and using the gasoline AFR since the lambda values basically line up instead of doing the math each time to reference it.
Old 11-16-2009, 06:13 PM
Zombie's Avatar
I was referring to people on the boards talking about the AFRs, one guy says too rich and the next guy says too lean lol. It is a bit confusing at first until it clicks.
Old 11-16-2009, 08:53 PM
needaz28's Avatar
ok,so i will gap them to .026 then I'll make sure I'm seeing at least 11.0 when boost hits. i guess nothing really changes, because when we tuned before we tuned it to 10.5-11.0 when boost hit.
thanks
Old 11-16-2009, 09:00 PM
Restricted User
98Z28CobraKiller's Avatar
I run #8's NGK 7317 gapped at .022. I was blowing them out at .030.
Old 12-09-2009, 05:17 PM
maxgee's Avatar
I'm running 9psi on e85 with 19* timing and my plugs are at .32. Pulled them recently and they all look great. How much boost are you running?
Old 12-10-2009, 11:48 AM
needaz28's Avatar
I'm running 10psi on a stock bottome end with a 76mm turbo. Might put the bitch on kill here soon as I'm getting closer to putting a fresh motor in it. I'm going to try a jy 5.3 with a zo6 cam/springs/comp pushrods and 317 heads. Run that while I build my 400+ cube engine.
The car has gone 125 on a slipping clutch and cly 7 down around 100psi. The other 7 clys are at 150 psi. 9" is going in by new years. I think I can get a 5.3 to low 10's on "pump" gas. (E85)
Old 12-10-2009, 02:33 PM
BoostnTBSS's Avatar
i run 35 deg timing and tune to 7.6-8.1-1afr with tr8's at.025
Quick Reply: e85 turbo guys, need help.
