battery reloc. fuse question
150-200amp Do a search you will find all the info you need. Again this is just waht I've read so double check everything. Theres a lot of threads about this, with all the info you need.
Race your car!
I have a 200 amp in the wire that comes off the cutoff switch to the front of the car, and a 150 amp on teh wire running from the alt to the battery, that one is up in the engine bay by the alt. This way, the wires in the car, should they short out are going to have the power cut.
