Fueling & Injection - '98-'02 F-Body Gas Tank..Which Auto Meter Fuel Gauge?
Ford_Assassin
11-18-2009, 03:44 AM
Hey guys, I used a stock Camaro Z28 tank w/pump, pickup, and sender in my Datsun Z 6.0 LS swap.
I want to have a working gas gauge, but don't know which Auto Meter Sport-Comp gauge will work correctly (2 5/8 or 2 1/16").
If I knew what the full/empty ohm ranges are suppose to be I could figure it out on my own.
Thanks guys!!
Lonnies Performance
11-18-2009, 06:25 PM
I do not believe one exists to directly work with the Factory sender, but a programmavle one is supposedly available.
Never tried one before to know for sure.
The tank is 40 to 250 ohms.
I can get a replacement level sensor to fit your tank with 0-90 ohms (that works with a standard gauge), but they are approx. $150.
black98ws6ta
11-19-2009, 12:44 PM
I thought there was different years that had different sending units?
Ford_Assassin
11-19-2009, 01:56 PM
Its cool guys. Auto Meter sells a programmable fuel gauge for $100+. I guess that's what I'll be buying when the time comes.
Lonnies Performance
11-19-2009, 05:36 PM
Sending units & level sensors varied greatly in design through the years, but there were only 2 different level sensor ranges in all Camaro's made.
Up through '97 was 0-90 ohm & '98 up was 40-250 ohm.
Ford_Assassin
04-25-2010, 06:18 PM
Something like this should work, correct?
http://www.summitracing.com/parts/ATM-6310/
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
