422 LSX Solid Roller, TFS 245's, Billet Wilson & Twin TC78's from KYTP
Old 11-18-2009, 11:44 AM
Restricted User
98Z28CobraKiller's Avatar
Default 422 LSX Solid Roller, TFS 245's, Billet Wilson & Twin TC78's from KYTP
Here goes another build thread. THIS IS NOT MY VEHICLE. I am posting and will be maintaining this build thread for LS2Formula. I'm sure he will be involved and will pop in regularly.
Here's a run down of the major components:
LSX 422ci
TFS 245 6 bolt heads 70cc
Custom JE Pistons
Comp Cam 24x/24x .6xx/.6xx 11x Solid Roller
Jesel rocker system
Billet Wilson Intake
KYTP Custom Twin TC78 Kit
A2W Custom KYTP Intercooler
Rossle Powerglide fully upgraded
FTI Converter
9" Rear w/ 3.7x:1 gear
Nasty Performance Fuel system
Aluminum sumped tank
Twin Magna Fuel Pumps MP-430X
AMS1000 w/ CO2 Boost Controller
Big Stuff 3 from EPP
Old 11-18-2009, 11:46 AM
Fireball's Avatar
why such a small solid cam?
Old 11-18-2009, 11:47 AM
BLOWNBLUEZ06's Avatar
OMG! Can't wait to see it.
Old 11-18-2009, 11:51 AM
Restricted User
The KYTP Kit arrives on the truck
Here's what he got minus the water tank and pump that should be arriving shortly on UPS per Josh.
We picked up the motor last night also from Total Engine Concepts. Mike @ TEC builds all the Mosler supercar engines from mild to wild. He builds all of ours also. We rushed home to start throwing **** together.
Here's a shot of the engine bay (on the lift) minus K-member with the BS3 Harness in place.
Then the motor on the Kmember with the transmission
Old 11-18-2009, 11:52 AM
Restricted User
Street car.
Old 11-18-2009, 11:56 AM
Restricted User
While Steve (LS2Formula) was wrenching away, Joe (BonnarLS1) and I took a ride down the road to our very handy friend's house (Dave) to get the nipples cutoff the Griffin radiator and get some pimp style AN fittings welded on.
While we were out, Steve was making some progress back at the house.
Old 11-18-2009, 12:03 PM
Restricted User
His initial intention was to mount the radiator under the radiator cross support up front with notch for the radiator cap. This had the potential to look really good and clean but unfortunately, in an effort to make progress, we didn't test fit the turbo kit with the radiator in place. Here's what we found when we go back to his place with the radiator.
FAIL!
So it appears that he will be completely removing the cross support so that we can tilt the radiator as far forward as possible. This will also allow us to go up 2-3 inches which should give us enough space for an AN elbow to get the upper radiator hose to the water pump.
Old 11-18-2009, 12:20 PM
eviltwin_1987's Avatar
Should I throw a quarter down for this one too? What are has goals at the track in this thing?
Old 11-18-2009, 12:21 PM
ls2formula's Avatar
The motor was already solid roller from the last build.
Old 11-18-2009, 12:25 PM
Fireball's Avatar
Real men don't need TIG gloves
Old 11-18-2009, 12:29 PM
SS DNA's Avatar
hahaha
Old 11-18-2009, 03:13 PM
LS1RedZ's Avatar
Wow. Thats looks absolutely sick! Cant wait to see some numbers from this beast.
Old 11-18-2009, 03:26 PM
smokinHawk's Avatar
until he gets a nasty light burn.........
i cant weld sleeveless as a get a bad sun burn like
Old 11-18-2009, 03:27 PM
Restricted User
Lol. He was resting his forearm on it. He said that the little fins on the rad shock the **** out of you.
Old 11-18-2009, 03:29 PM
airforcemanss's Avatar
um...isn't that a little excessive for a street car lol? btw, why did you chose a 422 on the lsx? whats this thing going to rev too?
Old 11-18-2009, 04:43 PM
Restricted User
I'll take it. LOL
He was running pretty consistant 8.80's in the low 160's with this motor at 12.5:1 compression with a nitrous shot of just under 400 hp.
After tearing the car down 3 times because we had water leaking from between the block and the heads, the problem finally made itself visible in the form of a split deck. Each time we tore it down the heads had to be milled because one of the surfaces would be bad.
We sent the heads back to TEA and they determined that one of the castings was defective. Their solution was to replace the one casting that was bad. We explained to them that we had to cut on them 3 times and spent many labor hours (the top center head bolt on these 6 bolt heads is a HUGE pain in the ***) and over $1K in machining and headgaskets as a result of their defective casting. All we wanted in exchange was a SET of new heads. They refused and Steve got tired of fighting with them. He ended up paying for the second casting and they CNC'd it and swapped over the hardware from his other head free of charge. I was very disappointed with their handling of this situation and we told them that this build thread would be high visibility. I guess it didn't matter to them so here it is. This whole thing took several weeks to resolve as it seemed that Steve spent lots of time talking to an answering machine. If he wasn't so deep into those heads, he would have switched over to something else. But, it is what it is. Hopefully there wont be any more issues and all will be good from here on out.
So to answer your question as to the goals of this car, we are hoping to run bottom 8's. A high 7 on drag radials would be sweet. We shall see.
He ordered a bunch of fittings and misc stuff today to keep the ball rolling. We hope to fire it by the end of next week and get some low boost numbers within a couple of weeks.
I use the term street car very lightly. He wants to be able to take the car out on the weekend for a cruise and be able to drive it all over town without issue. It has all the power options, full interior minus the back seats, stereo system with nav and subwoofer, and working lights all around. Registered and insured. It had power steering but it's looking like that's going to be too much of a pain to retain with this kit. The A/C was removed but it might go back in as this kit does have space for the compressor.
We intend to rev it to about 7500 RPM but the valvetrain is good to over 8K. Just depends on where it stops making power.
Old 11-18-2009, 04:48 PM
GMCtrk's Avatar
ball bearing on the turbos or no?
Old 11-18-2009, 04:54 PM
bonnarls1's Avatar
great time last night los this is going to one bad ride when it's done!!!
Old 11-18-2009, 06:48 PM
Rickys S/C Z28's Avatar
damn yall got that much done in one night!!
LOL
nice looking build
Old 11-18-2009, 06:52 PM
MelScrilla's Avatar
that car should be a monster on the street and the track cant wait to see it done.
Quick Reply: 422 LSX Solid Roller, TFS 245's, Billet Wilson & Twin TC78's from KYTP
