Ls1 oil pump replacement.. pump choice?
Ok from looks of it , the oil pump is shot and needs to be replaced. I noticed some noises near the bottom end and saw my pressure gauge acting up when i slowed down and when i accelerated. The biggest was when i was sitting still and the pressure slowly began to fall but luckily i made it home and didnt tear any **** up.
The car is a 95 Z28 with a 98 LS1 from a T/A and has about 125,000 miles on it. Ive been driving the car just fine for about a year and a half now with the conversion but because the LS1 sat up for over a year, various parts have randomly gone out.
What kind of oil pump should i get? Ive heard the stock 98, 99, 00 oil pumps didnt produce much pressure as the newer ones and arent as reliable. Also what else you i think about replacing since im gonna have it torn apart like that? Im not camming it. ANY help would be greatly appreciated.
We have a ported and shimmed LS6 pump. It offers more pressure and more volume without any clearance issues between the timing chain or front cover. Issues that we have seen with other aftermarket pumps. It is a nice upgrade for everything from a cam only build to a big cube stroker motor!
Jon
Jon
Just a bit of useless info here but I measured the opening in the block at the pump exit (block entrance) and it is smaller than the exit hole in the pump body. There is a shoulder there becuase of this and I wondered if the hole in the block was opened to match if it would increase oil flow.
1 Post
