comp lsr centrifugal cams
Am looking to freshen up my v7 fed 383 ls1 in the near future. Talked to comp cams and they recomended one of their lsr cams. Has any one got any feedback on how these cams perform compared to say their xer series.
I have one of their LSR lobed cams in my LS3. The blower is a TVS. I think they are "bigger" than the duration #'s show. Lift is high compared to what most cams of similar duration spec. Mine is a 219/231 with .610/620 lift on a 115lsa. Idle is more aggressive than what you would expect for the specs. It made 670+ rwhp on 8.5psi with all the bolt ons on a manaul transmission vette. Drivability is good with little or no issues.
have bitten the bullet and ordered one of these lsr cams. Decided on the 243/259 116lsa. Should have it here in oz in new year and will see how it goes.
We have installed the the 243/259 cam. Havnt done a proper tune yet as needed some bigger injectors, but down low idle is not to bad and street manners are very good.
Yeh is pretty big but has 116 lsa as well. Talked to people at comp and they believed it would be ok so thought stuff it will give it a go. Its exact specs are 243/259 116 lsa. .624/.624 lift. Should have some figures in next week in regards to power and torque.
Vid of it not best sound as i think camera was a bit close.
http://www.youtube.com/watch?v=xB2E1vCKToU
Mine is in. I'm breaking the motor in NA then adding a turbo after break in. I'm using the 243/247 .624/.624 on a 116. It's not fully tuned yet, but it wants about 30% more fuel (according to my tuner) than my last cam which was a 242/248 .621/.615 on a 111 in a stock LS2 longblock. My new engine is only 9.3:1 compression with ported FAST 90 and 243 heads. So it's flowing more air than my last setup. Same headers and exhaust are being used. Only other change is OTRCAI by Svede and going Speed Density.
Comp Cams LSL Lobes
13014R 265 215 139 .355” .604”
13015R 269 219 143 .357” .607”
13016R 273 223 147 .359” .610”
13017R 277 227 151 .361” .614”
13018R 281 231 154 .363” .617”
13019R 285 235 158 .365” .621”
13020R 289 239 162 .367” .624”
13021R 293 243 166 .367” .624”
13022R 297 247 169 .367” .624”
13023R 301 251 173 .367” .624”
13024R 305 255 176 .367” .624”
13025R 309 259 180 .367” .624”
13026R 313 263 183 .367” .624”
13027R 317 267 187 .367” .624”
13028R 321 271 190 .367” .624”
13029R 325 275 193 .367” .624”
Comp Cams LSL Lobes
