ms4 ?
Old 11-20-2009, 02:58 PM
SScamaro4's Avatar
Thumbs up ms4 ?
what pushrods do i need to use when installing an ms4 cam in my ls1? ill be hopefully using my ls6 heads people are telling me i need 7.425 or 7.45s someone help me
Old 11-20-2009, 03:02 PM
PERFECT Z28's Avatar
call TSP for the best info
Old 11-20-2009, 03:18 PM
02*C5's Avatar
You need to check the rod length with a pushrod measuring tool. Do the measurement and then buy the rods. This is a place that you need to actually check the length, unless you are replacing stock pushrods to your stock valve train and stock cam. But its up to you.
Old 11-20-2009, 08:53 PM
SS4Luck's Avatar
TSP can give you a measurement if everything else is stock in the motor, its what they did for me and mine are great
Old 11-21-2009, 10:21 AM
mwatson185's Avatar
Just get an adjustable pushrod to find out for sure. I'm guessing you will end up around a 7.4-7.425 though.
Old 11-21-2009, 10:30 AM
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
It's always best to check with a checker to be sure. We stock both the 7.400" or 7.425" whichever you choose!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
