Looking for parts list for all harnesses
I have the trans out for the third time. Just got a new slave in, bleed the lines, got great clutch pressure, started the car, pressed the clutch twice to ensure there was pressure prior to putting it in gear then heard a plastic pop. The hydrolics lost all pressure and the pedal stayed to the floor. I assume the seal was bad. anyway that slave is toast. This is now the second one. It will go back to the company tomorrow.
Anyway...I have two broken plastic connectors and am trying to find what parts numbers to order. I have no clue what the two senors are. I know pretty bad considering I build the car but never really paid attention to the transmission until recently.
I only need new connectors (from the engine side) and not the whole harness (splicing/soldering is the easiest way). If I have to buy the whole harness that is fine too.
Thanks for any and all help.
1. I think this is for the skip shift? If so no big deal that is disabled wth the tune.
2. Is this a pressure sensor or temp sensor? The connector is brown.
