Drag Racing Tech
white smoke ?
Old 11-22-2009, 05:17 PM
I write checks with my mouth that my ass can't cash
00blacka4's Avatar
Default white smoke ?
okay so i never noticed this before i put the JET programer on preset tune 3 and removed the screen in my mass air meter now when i start it it smokes white a little, also when i get on it and stop there is some smoke sometimes WTF is it...somone told me to change my oil and filter...is it the tuner cuz i can take it off..i know its not about drag racing but it seems like i get responses the fastest on here
Old 11-23-2009, 12:06 AM
SPEED#1's Avatar
Coolant leak, maybe a bad head gasket?
Old 11-23-2009, 09:20 PM
00blacka4's Avatar
ya i think it was condensation because i started it after school today and it didnt even do it a little...so im not worried about it
Old 11-24-2009, 12:16 PM
tee-boy's Avatar
pressure test the cooling system. That'll tell you if you've got head gasket failure.
Old 11-24-2009, 02:48 PM
JUICED96Z's Avatar
Id check for oil in the coolant or coolant in the oil just to make sure.... I have never heard of condensation doing that but that does not mean it can't happen.
There is a pricey tool Snap-On makes (I think it is Snap-On) that tests the coolant for a blown head gasted......... neat little tool.
Old 11-24-2009, 05:39 PM
tee-boy's Avatar
Default fdfdfd
good point. but on a chevy, not likely to get oil in the coolant since it oils through the push rods, unless you've got a broken compression ring on a cylinder.
I would say it's likely either coolant in the oil (head gasket failure - check w/ a radiator leak down guage) or bad valve seal (would be a grey smoke and not white).
Old 11-24-2009, 10:30 PM
00blacka4's Avatar
its nothing, i only noticed it a little pulling out and it kinda lingered but it was almost clear and it hasent done anything since and all the fluids are full and good looking....off subject but i just bought mobil 1 full synthetic and a wix filter for my oil change and all together with a little extra oil it cost me like over 50 bucks !!! i was like damn.
Old 11-25-2009, 01:16 PM
JUICED96Z's Avatar
Yup but it is mowrth it when you only have to change your oil every 8k miles or so.
Old 12-03-2009, 10:03 AM
TA_BUD's Avatar
i wouldnt worry about it, only if you run your car hard all the time
Old 12-03-2009, 10:09 AM
89IROC's Avatar
like u said it was probably just condensation, H20 is a biproduct of combustion....
