Ideas for purge on '00 z!!
Old 11-23-2009, 02:32 AM
rcastillo002's Avatar
Default Ideas for purge on '00 z!!
So working on getting a nitrous kit here... car has the SS hood... just wondering if anyone has any good ideas for how or where to purge the nitrous. maybe through the SS scoop? or just straight up by the windshield on each corner? hopefully someone has some creative ideas here.. pics or vids would help... thanx guys...
Old 11-23-2009, 09:46 AM
Nick@HSW's Avatar
I think they look good up by the window or down in the nostrils on the T/A's.
Nick
Old 11-23-2009, 01:03 PM
yeah it looks really good on the ram air hoods on ta's... but i have the SS hood... not sure if it will look close to decent that way... i guess i can just shoot it straight up by the windshield on the 2 corners...any other ideas guys?
Old 11-29-2009, 02:34 AM
tnmotown's Avatar
I have got the single purge and thinking about having it right in the middle of the windshield coming out the cowl area.
Your avatar says your in the central valley, where at? Just asking because im in turlock
Old 11-29-2009, 05:29 AM
bills98ta's Avatar
I put mine beside the headlights...
Old 11-29-2009, 09:49 PM
Nitro Dave's Nitrous Outlet's Avatar
Thats cool. Reminds me of diesel stacks..
Old 11-29-2009, 09:54 PM
I have done it both ways. We offer a kit so that you can do a clean install no matter which way you go.
Here is the windshield kit.
http://www.nitrousoutlet.com/catalog...4&product=2757
Here is the Hood exit kit.
http://www.nitrousoutlet.com/catalog...4&product=2758
Dave
Old 11-29-2009, 10:23 PM
bills98ta's Avatar
Stage 1
Stage 2
300 Shot Launch
Old 11-29-2009, 10:40 PM
Awesome pics.. What all do you have done to the car?
Dave
Old 11-30-2009, 06:42 AM
bills98ta's Avatar
Dave
Now that's a big question ! LOL
Stock cube LS1, 14:1 CR with 5.3 heads, big cam, 150 dry shot, just added a 200 direct port, 4600 stall on the built 4l60e, moser with 4.10 gears, every suspension mod in the rear, doing the K-member this winter, and wheelie wheels. Ten years of EBay !!!
Old 11-30-2009, 06:49 AM
bills98ta's Avatar
Still need that special harness that keeps my nuts from rolling under the seat when the car slams down... EBay doesn't have those...
Old 11-30-2009, 07:39 AM
BAKED's Avatar
What kind of times does it run? Killer looking car BTW!
Old 11-30-2009, 07:55 AM
bills98ta's Avatar
10.60 on the 150 dry shot. That 300 shot launch did pull a 1.35 60 foot, but I only 1/8 miled it with a 6.47 from a normal 6.74... I need to upgrade to a dual fuel pump system...
It ate the plugs...
Old 12-02-2009, 04:27 PM
Hey tnmotown... I'm in The Visalia area...
Old 12-02-2009, 04:30 PM
50 dollars that sounds like a pretty good deal to me lol... I think I'm gonna be visiting your website pretty soon for that dual hood purge...
Old 12-02-2009, 07:08 PM
BAKED's Avatar
It ate the plugs...
If it ate the plugs it either has the wrong ones in it (too hot) or it has too much timing. Awesome times regardless!
Old 12-02-2009, 07:24 PM
bills98ta's Avatar
I was told that one walbro 255 would not handle it... Guess they were correct ! I did pull the timing down to 22* plus added to the PE tables above 4000 rpm, but, it still ate them !
I always run the cheaper Autolite 103's, they will melt before the piston... At least I hope ! LOL !!!
This winter, new fuel system & cm K-member !!! Need to loose some weight on the front !!!
Old 12-02-2009, 07:27 PM
bills98ta's Avatar
What plugs and timing would you recomend ?
Old 12-02-2009, 08:22 PM
camscam02's Avatar
I would also say you had way too much timing in that thing, it takes heat to melt the plugs, aka too hot off a plug and too much timing. 22 degrees is way too mich for a 350 hit.
It should prolly be in 15 area with that much in it with -9 plugs or maybe even 10's. non projected ofcourse. What fuel are you running as well?
Old 12-02-2009, 08:31 PM
bills98ta's Avatar
Sunoco 100 unleaded.
I usally run 26* on the 150 dry shot & have 46lb injectors to compensate. They run about 60% duty at WOT.
Guess I could chill it down a few notches...
