possible causes for rev. input drum failure?
Old 11-23-2009, 08:53 AM
Trips's Avatar
Default possible causes for rev. input drum failure?
I lost 2nd gear and 4th was pretty weak so i dropped the trans, pulled the pump and found this.
the band is all black and pitted/worn out as well. I got a new band and a new reverse input drum is on the way...
Any ideas as to what would cause this? My guess was the servo or apply piston, but I'm not sure what a good way to test them out would be.
Old 11-23-2009, 11:17 AM
LS1Tech Sponsor
performabuilt's Avatar
What are you using for servo apply pistons, You also should check the 1-2 and 3-4 accumulators
__________________
Built..PerformaBuilt..Tough
Call 888-744-6542
Old 11-25-2009, 01:08 PM
Trips's Avatar
the servo's and piston are stock, and none of the seals were leaking. As for the accumulator pistons - none of them are cracked or anything, and they don't appear to be worn. However I did notice two of the holes in the valve body separator plate were kinda banged up and a little out of round, not a lot but noticeable.
