Modified 1997 WS6 Formula M6
Old 11-23-2009, 06:40 PM
5.7NSIDE's Avatar
Default Modified 1997 WS6 Formula M6
1997 WS6 Formula
389rwhp
ENGINE
Modified 355 LT1 with Less Than 15k Miles
6" Forged Rods
Wisco Forged Pistons
Stock Crank
11.5:1 Compression
Balanced Rotating Assembly
Advance Induction CNC'd LT1 190cc Heads
- CNC Ported Intake and Exhaust Runners
- CNC Unshrouded Combustion Chambers
- 100% CNC Competition F1/Cup Quality Valvejob
- Valves Prepped and Back Cut
- Steel Jacketed Viton Seals
- Stainless Competition Plus Super-Flo Valves 2.00" Int/1.56 Exh
- CompCams "Beehive" Springs
- CompCams Machined and Hardened 10deg Retainers, Locators, and Locks
Comp Cams - Custom Ground by Advance Induction
Comp Cams - Hardened Push Rods
CompCams 1.6 Roller Rockers
ARP 7/16" Pro Series Rocker Studs
ARP Head Bolts
Holley 58mm Throttle Body
Factory Engine Oil Cooler
Ported Intake by Advance Induction
Ceramic Coated Intake, Valve Covers, Brackets, Ect. by Air Borne Coatings
Tuned by Carolina Auto Masters in Durham, NC
TRANSMISSION
T56 6 Speed
- Rebuilt by D&D Performance
- Steel Shift Forks and Dog Legs
Ram Power Grip Clutch/Pressure Plate
Pro 5.0 Short Throw Shifter
REAR END
Stock Rear End Housing
SLP 3:73 Ratio Gears
Auburn Posi-Unit
Moser Hardened Axles
TA Performance Aluminum Cover
EXHAUST
Jet-Hot Ceramic Coated 1 5/8" Headers
Custom 3" Y-Pipe Ceramic Coated (No Cats)
Borla Exhaust System
Entire Exhaust System Ceramic Coated by Air Borne Coatings
SUSPENSION
RaceCraft Tubular Front K-Member
Spohn Performance Front Tubular Control Arms
Random Technologies Adjustable Torque Arm
SLP Drive Shaft Saftey Loop
Edlerbrock Ajustable ISA Coil Over Front Shocks
Eibach Pro-Kit Rear Lowering Springs
Hotchkis Sway Bar Kit, 1 716" Front, 1" Rear
Hotchkis Rear Control Arms
Hotchkis Adjustable Pan Hard Rod
Hotchkis Sub Frame Connectors
Hotchkis Strut Tower Brace
Energy Suspension Sway Bar Bushings and Links in Red
KYB Rear Shocks
All Parts Powder Coated in Red or Black
BRAKES
Baer 13" Front Track System
- Cross Drilled, Slotted, Zinc Wash
- 2 pc Eradispeed-Plus Rotors
- Black Powder Coated Calipers with Baer Logo
Baer 13" Rear Track System
Baer Braided Flex Hoses - Front and Rear
Still Retains the Stock ABS System
WHEELS & TIRES
Original GM C5 Corvette Z06 Wheels
17x9.5 Front with 275/40-17 Firehawk Wide Oval Tires
17x10.5 Rear with 295/35-18 Firehawk Wide Oval Tires
BODY
105k miles on Body
Original GM Red (Repainted in 2004)
Original GM Functional WS6 Ram Air Hood
Original GM Ram Air Box with K&N Air Filter
Trans Am Style Rear Spoiler
Power Antenna
Tinted Windows
INTERIOR
Red Leather Iterior
Power Lumbar Seats
Power Windows, Locks, and Mirrors
Factory Alarm Sytem and Keyless Entry
Silver Face Gauge Inlays
SLP Floor Mats
Red Shifter Ball with Pontiac Crest Logo
Old 11-23-2009, 09:03 PM
LoudGM's Avatar
$6500
Quick Reply: Modified 1997 WS6 Formula M6
