MS4 110+3 Ground advance
LS1Tech Premium Sponsor
The main issue with that will be piston to valve clearance! What short-block are you running, or more importantly, do you have valve reliefs in your pistons?
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Advancing a cam, opens the Int valve sooner and closes it sooner, bringing the power earlier in the band and making the cam more exhaust bias. Basicaly it shifts the powerband a bit sooner.
On a cam like MS4, it will not make a huge difference since the Intake closing IVC is allready beyond most intake manifold flow capabilities (LS6/FAST) so it will not affect your top end dramaticaly but it will make the cam even harder to tune because of reversion increase.
