high idle and auto rev when movimg
Old 11-24-2009, 06:50 AM
Altekameraden's Avatar
Default high idle and auto rev when movimg
My car idles at 1800 when I'm coasting to a stop in gear or neutral, and if I don't hold the clutch in it willll usually rev to 3000 until I'm stopped then it steps down in 500 rpm increments to 900rpm. I've changed. IAC, TPS, MAF, MAP, air lid, searched for vacum leaks, even tried new TB always same. Throttle cable and pedal act normal. This problem happened before heads, airlid. Appreciate the help I hope its not the pcm
Old 11-24-2009, 06:11 PM
Guess this is an insane problem that is very rare.
Old 11-24-2009, 06:21 PM
FASTEDDIE Z's Avatar
Do a search on " throttle cracker " It might help you out .
Old 11-24-2009, 10:21 PM
devious's Avatar
x2 man, your problem lies within the tune, i highly doubt it is mechanical.
Old 11-24-2009, 11:13 PM
hlaalu's Avatar
have you popped the hood and checked to see if the throttle blade is sticking?
Old 11-25-2009, 05:46 AM
Yeah the past 8 months I've ruled out all mechanical problems that are on the searches in forums, so I'm convinced its tune
