Bad Blue WS6
11-24-2009, 11:44 AM
Hi all!
If my pinion angle was out;
1. Would i have vibrations in any gear, but always the same RPM range? (lets say 1800 to 2500 for example)
2. What would putting about 2 to 3 thousand miles on a "out of whack" pinion angle cause,, any damage to other stuff? Im going to replace the U joint but wanted to know if i should be checking anything else out
Chasing Vibs and to be honest once i put my new rear in, i did not check pinion angle due to stock height, etc (im using a non adj BMR TA),, but as i learned with having my thrust angle out (was using UMI non adj LCA's, and had to buy adj ones to fix that issue), im afraid that my pinion angle is what is causing my vibrations,, getting a angle finder today to verify this week at some point (when i can get it on a lift)
Thanx all
Wayne
Thanx all
Wayne
