Where is best place to buy a LS1 383 stroker kit ?
Need a lot more info to give you a good advice. First off will it be an NA, nitrous, or turbo build? What horsepower do you want? What is your budget? Pump gas or race gas? What to you is a best? To me a best would be quality. So please give more info.
Im using a callies compstar setup, i was pleased with them, but i have also heard that lunatti is really good. I think they are inside your budget on price too.
5k for stoker kit? for that budget just buy a short block. your goals are fine with eagle/ diamond components but like the other guy said, i like and prefer compstar components with high end pistons. check texas speed for a good budget set up
LS1Tech Premium Sponsor
We have special pricing on the 383ci rotating kits at the link below:
http://www.texas-speed.com/shop/item...d=884&catid=88
Also there is special pricing on the 383ci short-blocks currently as well!
http://www.texas-speed.com/shop/item...id=43&catid=86
Let us know if we can help with the component selection for either of those
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
We can set you up with everything from Scat Eagle or Compstar to Carrillo and Sonny Bryant. But it comes down to application. What is the engine intended for. Then we can decide what the best assembly to go with is. You budget for just the assembly is way over blown unless you need it to be ultra light and strong?
