Best junkyard heads? I need a shopping list!!
Old 11-25-2009, 03:44 AM
98camaro28's Avatar
Default Best junkyard heads? I need a shopping list!!
Ok so here is the deal: I found a local junkyard with around 40 or 45 LS/LQ engines (at least 20 are 5.3s), and for pretty cheap. I want to know what heads would be the best to replace my stock 98 heads when I put my MS3 in. I plan on getting several sets to "tinker" with since the prices are pretty good. What would be the best UNPORTED heads to look for? Can someone make a list of heads and cast numbers to look for in order of best flowing to worst? ANY help is appreciated! THANKS!
Old 11-25-2009, 03:51 AM
Nitroused383's Avatar
Look for casting number 243 or 799. They come on newer trucks 06+ I think, 05-06 gto, c5 z06, and C6 LS2 vettes.
Old 11-25-2009, 10:18 AM
BaddBird's Avatar
243s also came on the 5.3s (ls4) in the 04 and up grand prix gxp and the impala ss.
Old 11-25-2009, 10:27 AM
Benner's Avatar
Originally Posted by BaddBird
243s also came on the 5.3s (ls4) in the 04 and up grand prix gXp and the impala ss.
Fixed
Old 11-25-2009, 11:02 AM
98camaro28's Avatar
Will do! Where on these heads can I find the casting number? And how much of a gain, if any, will I get over my stock 853s?
Old 11-25-2009, 11:18 AM
deadhorse66's Avatar
You can probably look for in the neighborhood of 15 horsepower over a stock LS1 casting. Look at the left bank, front top of the head just below the valve cover rail, and you will see a 3 or 4 digit code on any LS based engine. A little fyi, the 799s are probably more rare than even a 243 nowadays, as they only came on 5.3 L33 engines which is the aluminum block Gen III high output. 243s are used on a LOT of newer (07-up) truck 5.3s. While they dont have the sodium filled/hollow stem valves, they have the same port design they've always had.
Old 11-25-2009, 11:31 AM
BaddBird's Avatar
Originally Posted by Benner
Fixed
Thanks for the correction.
Old 11-25-2009, 02:57 PM
98camaro28's Avatar
OK. So of those 2, which would be better? 799 or 243?
Old 11-25-2009, 03:04 PM
They are the same head just cast by 2 different foundries. The 243 supposedly has a smoother casting, but not by much.
Old 11-25-2009, 03:49 PM
Red99T/A's Avatar
how much can one expect to pay for a set of these heads from a junk yard?
