Gen 5 Camaro Drivetrain Tech - Gears!
jay_lt4
11-26-2009, 03:29 AM
http://www.lingenfelter.com/mm5/merchant.mvc?Screen=PROD&Store_Code=LPE&Product_Code=L380011410&Category_Code=C366
and someone else posted richmond gears facebook page says they will have them also next month
blackjack325
11-26-2009, 08:29 AM
those 3.70 gears come out on the G8 right? would the G8 gears fit the Camaro???
jay_lt4
11-26-2009, 01:12 PM
nope, the camaro diff is all by itself, the g8 and cts-v are different
Pro Stock John
11-26-2009, 01:31 PM
The 2010 tires are so tall that most folks could run 4.10's with a power adder and the overall gear ratio is still very rpm friendly.
jay_lt4
11-26-2009, 02:48 PM
ya, 3.27 gears with a 28.5" tall tire, stock
i think the 3.70's will help alot
NumberOneSled
11-26-2009, 05:12 PM
$799 for the gear set?
jay_lt4
11-26-2009, 05:18 PM
yes for the ring and pinion
rayhawk
11-26-2009, 10:06 PM
It is all relative because the transmissions are geared differently. Look at the rpm in each gear at a given speed between a 3.42 rear M6 2002 camaro with 25.5" tires and the same for a 3.45 rear 2010 M6 camaro with 28.5" tires and you will see they are nearly identical. So, in other words, a 3.73 in a 2010 will be a nearly identical change that a 3.73 would be in a 4th gen. The A6 is a bit of a different story, as you can't really compare it directly to a A4 4th gen. Besides, the A6 in the 2010 is geared pretty aggressively already, even with a 3.27 rear.
Pro Stock John
11-26-2009, 10:23 PM
If this is the 6 spd manual gearing
TR6060 six-speed manual (SS)
Gear ratios (:1):
First: 3.01
Second: 2.07
Third: 1.43
Fourth: 1.00
Fifth: 0.84
Sixth: 0.57
Reverse: 3.28
Final drive ratio: 3.45
Then the gearing is not much deeper than a 4th gen, so I'm not sure I'd do 3.73's vs. stock 3.45's.
Dark SS
11-27-2009, 11:06 AM
I think a 3.90 would be perfect with the M6
Tainted
11-27-2009, 07:21 PM
holy shit thats expensive for a set of gears! i remember fbody gears were under 400$
blackjack325
11-27-2009, 08:47 PM
that is way too much $$$ for gears.....
so you all think 4.10s would be a good gear for the 28.5" tire?
juicdta
11-27-2009, 10:13 PM
hahah look up gears for a vette. i about shat myself when i was looking at doing them
rayhawk
11-28-2009, 04:49 PM
Gear ratios (:1):
First: 3.01
Second: 2.07
Third: 1.43
Fourth: 1.00
Fifth: 0.84
Sixth: 0.57
Reverse: 3.28
I agree, I'm just saying that the tire size difference is compensated for with the different trans gears.
ss1129
11-29-2009, 06:12 PM
You have to pay the corvette tax now on the Camaro. I mean do you guys read the average post on one of the new Camaro websites? They think $600 for a CAI is a good deal and will net them over 30rwhp. They are pretty much domestic ricers.
grocerygetter
11-29-2009, 07:59 PM
that's a little over the top there ss1129...but I do agree with the "new camaro tax" and that there are WAY too many noobs on camaro5 dropping 7-8K on mods right out the gate.
