Yella Terra Bolts??
Yella Terra Bolts??
It is obvious what they are for, but i just opened up my box of new yella terra rockers, and low and behold there are 16 allen head bolts with them. The instruction sheet says to re-use the stock bolts. I am sure that it really doesnt matter, just wanted to see what some of you have done. Thanks.
I had an issue with the stock bolts not fitting well in the rocker so I used the allens. In the end, because of the shimming I needed to get the wipe correct, I actually bought longer bolts to ensure full thread engagement of the bolts. You can see the allen heads in the photo. Make sure you set the wipe first, then check pushrod length.
