ALUMINUM OR STEEL FLYWHEEL? Need help choosing
Old 11-26-2009, 04:02 PM
82cetuner's Avatar
Default ALUMINUM OR STEEL FLYWHEEL? Need help choosing
I am going to take advantage of the monster clutch sale, However I am torn between the aluminum or steel flywheel I don,t know what would be best for my needs.
I have a 82 Corvette ls1 T56 with 4.11 Gears. car is about 3000 Pounds.
I plan for this car to be a Daily Driver but what I want to know is what are the pros and cons of each
Pros and cons of Aluminum flywheel?
Pros and cons of Steel
I plan to swap out the stock LS1 for a 402 ls2 and stage 3 243 heads and a TQ V2 cam in about two years, but for now the LS1 is stock but might get upgraded with heads and cam that I can swap to the 402 later.
Price is not a issue btw its only about a 50 dollar difference
Old 11-26-2009, 04:33 PM
sixpack_2_go's Avatar
with a light weight flywheel your rpm's will fall a lot quicker. if your looking for daily driving or drag racing most people prefer the steel flywheel.
Old 11-26-2009, 05:47 PM
BADD SS's Avatar
at 3000 lbs, aluminum will be fine....
Old 11-27-2009, 08:07 AM
Chris05ssTruck's Avatar
+1 with that weight you will be fine. I weigh more than that, and love mine. IF you can power shift good, there is no worry. But if you granny shift thats when the RPM drop will be noticed.
Old 11-29-2009, 07:37 PM
hivoltagedriver's Avatar
I replied to this in another thread, but Monster does not offer aluminum flywheels any more. Their lightweight FW is an 18lb billet steel F/W, versus the standard weight 28lb. More durable than aluminum, and can be resurfaced a couple of times if needed. I have one in my 3500lb DD GTO, and I love it. The rpm's do not fall between shifts if you shift quick enough... but seriously, it has not been a problem for me. I let my wife drive the car tonight, and she did just fine with it. I'm still running stock 3.46 gears too BTW.
Quick Reply: ALUMINUM OR STEEL FLYWHEEL? Need help choosing
