help needed
help needed
My setup is going to be the following; stock bottom end ls1, FAST 92mm intake, longtubes, patriot stage 2 ls6 heads, FAST 36lb injectors, lpe fuel pump, ported ls2 throttle body, I want a giant cam, something with great peak horsepower, as well as a strong running curve, I don't care a bit about drivability, this will be in an m6 c5 vette with a 3.73 gear. How big can I go? I will also be spraying 100-150 wet at the track only, so a nitrous friendly cam isn't completley necessary
