Slave Cylinder disassembly
Old 11-27-2009, 03:37 PM
Berto's Avatar
Default Slave Cylinder disassembly
I am trying to take apart my slave cylinder so that I can remove the spring so I can measure to see if I need to shim the slave cylinder for the clutch. but I have pulled on it and the dang thing wont come apart.
Is there any trick to it?
Thanks,
Berto
Old 11-30-2009, 11:16 AM
Berto's Avatar
Bump, can anyone help?
Old 12-01-2009, 05:01 PM
Berto's Avatar
Wow this must be a pretty in depth procedure if 43 people have viewed it and no one responded?
Old 12-02-2009, 06:54 AM
DJB
12 Second club
DJB's Avatar
If you look at the slave there is a spot that looks like it has a grind mark on it. Put a screw driver on that spot and gently pry and work the throw out bearing off.
Old 12-02-2009, 07:23 PM
1BADAIR's Avatar
there are 2 tabs. rotate the plastic until the other tabs are on top of the other 2 and it will pull off
Old 12-02-2009, 07:56 PM
Berto's Avatar
Thanks guys, greatly appreciated.
Quick Reply: Slave Cylinder disassembly
