Drag Racing Tech
what kind of SFCs for drag !!
Old 11-28-2009, 12:23 AM
I write checks with my mouth that my ass can't cash
00blacka4's Avatar
Default what kind of SFCs for drag !!
so UMI is having a huge sale and im going to order my SFCs tomorrow from summit...i want to go with the 2 point...for less weight, and easier exhaust fit, and i want to go with boxed weld in because there the more sturdy than tubular bolt in or weld in....i just dont know which one to go with because theres like a thirty dollar price difference in the choices ??? someone help me out
Old 11-28-2009, 02:17 AM
spoonraker's Avatar
Can't got wrong with boxed weld-ins. I don't know why anybody gets bolt in ones, do you really ever remove them?
Old 11-28-2009, 02:46 AM
KCFormula's Avatar
Only when you upgrade to a rollbar and they are just added weight.
Old 11-28-2009, 07:01 AM
UMI Performance's Avatar
Hello,
Thanks for the interest and I will be glad to help.
Our tubular weld in and boxed weld are about a $15 difference during the sale, with the boxed being the more expensive of the two.
Both styles would work just fine for any application. The tubular style is 4lbs lighter than the boxed style and also tuck up a little better into the car. Boxed style hangs down below the pinch of the car approximately 3/8" and can be seen from the side fot he car. I know some people like this and some don't.
If I can help anymore please ask. Thank you!
Ryan
Old 11-28-2009, 10:47 PM
00blacka4's Avatar
yes acctually 4 lbs. lighter is enough to make me think..will the tubular be plenty strong for me ?...do i need the boxed really...i dont care about seeing them or whatever. i want to go with the lightest, but enough strength.
Old 11-28-2009, 11:43 PM
JeaneZ28's Avatar
For people that dont wont to weld on there car and if you ever might put the car back to stock you can just take them off. Also for people that dont have a welder can just bolt them up.
Old 11-29-2009, 06:39 AM
Yes the tubular style will be just fine and there is no strength issues. The tubular style requires a little less welding and fab time.. that is why they are priced less.
Hope that helps,
Ryan
Old 11-29-2009, 09:25 AM
00blacka4's Avatar
i noticed the chromoly tubular ones exactly like the regular tubular ones are 100 dollars more expensive...is this necessary ?
Old 11-29-2009, 09:43 AM
JeaneZ28's Avatar
Those are for someone who wants a lighter and stronger sfc. Unless your running some badass times at the track I wouldnt waste the money.
Old 11-29-2009, 09:51 AM
00blacka4's Avatar
one more question, do i need adjustable LCAs or can i just go with the non-adjustable ?
Old 11-29-2009, 10:02 AM
ramairroughneck's Avatar
If you lower the car you will need adjustable lca's to center the wheels in the well.
Old 11-29-2009, 12:13 PM
00blacka4's Avatar
im not going to lower my car so ill just order the non-adjustable...how much will lower control arms help my launch ??
Old 11-29-2009, 12:17 PM
00blacka4's Avatar
i should order just the tubular LCAs right ? they have boxed also
