twin turbo front mount
Look here....
https://ls1tech.com/forums/forced-in...t-up-faqs.html
truck manifolds have been over 1000+ hp the kit is only reliable as you build it. Sounds like you do not know much about turbo setups. That turbo setup above is a expensive build and well over 600. If your looking for 6 then truck manifolds with a single turbo will get you there with ease.
Look here then...
http://www.byunspeed.com/index.php?o...c07142a0722643
And by the way there are a lot of twins based off of truck manifolds in the post.
i didnt see any twin setups in the link but ill keep lookin, i dont think most of u guys understand what im sayin, during the winter i plan to make my own setup, im co owner of a fab shop and we can do all mandrel bent stainless or aluminum, so right now im lookin for some fab ideas, im thinkin since im stock k member, i wanna make a custom set of mounts that will allow more room. any input or suggestions are apprecitated, thanks
thanks for the pic hunter, ive always loved the poistioning of your turbos, i had a few questions though, if i run twins, will the oil from above the filter be enough to supply both of the turbos and guarentee good life?(i know it usually depends on the turbo)and did you run your drains to the pan or front cover? and my other question was, if you had the tools available to build your own forward facing headers, would you have done it? i an co owner of a fab shop and was wondering if i should bother or just run manis, i wanna do headers because i think down pipe could be alot easier to run through.
yea i guess we r in the same boat, lol, i like the truck manifold idea but i dont like how they point down at the ground, i think im goin w custom headers, just because it wouldnt be much at all for us to make em at the shop, and so i can do the higher mounted turbos like hunter02ss, im basically doin twins to be different, now if someone could please answer me about the drain lines, id really hate to run a scavenge pump..........
