Smoked new clutch on 1st pass
Old 11-28-2009, 08:04 PM
RyanSws6's Avatar
Default Smoked new clutch on 1st pass
Well, I decided to make my first pass with my 408. Before I left home I noticed R was getting tough to get in. But my whole set up is 1k old (500 broken in). I got NEW GM slave and master and Centerforce clutch/flywheel.
Ok, with DRs did a nice burnout and rolled to the line, no RPM drop off the line, I just let it out and mash gas. Well it pulled the nose up real nice and hooked nice, second no issue real nice, Third WTF hit a wall wouldn't go in. I just went into 5th and spun/burned the clutch. Smell and smoke out the back. I couldn't believe it burned in 5th!!
Now R is real hard to get in and grinds and all gears are not easy. Pedal feels hard too.
I've never had this issue with an m6. Is it my slave, master or clutch? Its Fing new all of it! Might be a combo of slave/clutch etc...either way I'll need a new clutch! I got their flywheel/clutch as a kit so does mean I'm stuck with centerforce? I got the dual friction 12" set up. I didn't expect this!!!!!
Old 11-28-2009, 08:32 PM
ls1pwrdss's Avatar
did you measure for a shim properly when setting up the clutch ?
Old 11-28-2009, 10:27 PM
RyanSws6's Avatar
No, since I bought a complete kit and none of the paper work said anything about shims.
Old 11-29-2009, 08:16 AM
418redz28's Avatar
that sucks i have been through stuff like that. if u decide u need a clutch let me know i have a used mcleod twin disk for sale. good luck on finding out what it is
Old 11-29-2009, 08:18 AM
Chris05ssTruck's Avatar
Sounds like it might be a pressure plate problem from the way things sound.
Old 11-29-2009, 09:36 AM
derrick0811's Avatar
i just got the same clutch and i called centerforce last week and there rep said no shims are required with this clutch. id call them he easy to work with. but mine was hard to get into r too it happend to be my master was binding to i tightned it down and and rebleed and worked great
Old 11-29-2009, 09:50 AM
rabiddog's Avatar
Sound to me that you need to get in there and look at your clutch. I would check your pp bolts. Did you torque to spec?? check springs on pp clutch look for anything broken. Sounds to me like something is loose inside your tranny for the pedal to be hard and the clutch to be slipping.
Old 11-29-2009, 01:56 PM
RyanSws6's Avatar
Yeah no mater what the trans needs to come down. The pisser is I bought it ALL new so that I wouldn't have this problem. I'm going to call CF see if maybe I can get a new disc.
Old 11-29-2009, 07:57 PM
post on here your results..
