Will lowering springs even out the front/rear ride height?
Old 11-29-2009, 06:06 PM
crimson_bird's Avatar
Default Will lowering springs even out the front/rear ride height?
i've been looking at springs to lower my Trans Am. i was originally looking at the Eibach pro-kit, but with all the bad reviews i've heard from them i'm probably going to go with Strano's.
So, like my heading says, i'm wondering if springs will even out the cars height. right now it sits noticeably higher in the rear than the front.
Old 11-29-2009, 06:53 PM
BandDirector Blk98ZM6's Avatar
I'm on Strano springs and Koni shocks and my rear is about 1/4" higher in the rear. I like it! It's a MUCH better stance than the Pro-Kit I just got rid of and it rides MUCH, MUCH, MUCH better too!
Can't go wrong with the Strano springs!
Old 11-30-2009, 06:51 AM
teke184's Avatar
my BMR springs have the height almost identical all around.
26.5" at the highest point on all 4 wheel wells.
Old 11-30-2009, 11:57 PM
^thanks.
anyone else
Old 12-01-2009, 12:37 AM
therealcreeper's Avatar
to even it out a little you can always just take the spring isolator off of the top of the rear spring and replace it with some heater hose to even it out a little. known as the "heater hose mod" for anyone who has not heard of this before.
Old 12-01-2009, 03:54 AM
ben77's Avatar
heater hose mod ftw!
Old 12-01-2009, 09:39 AM
^thanks for the tip guys. i've heard about that mod a lot, but never really looked it up. i finally just read the write-up so i'll probably do that tomorrow. that should hold me over until i get my springs sometime next month.
Old 12-01-2009, 10:14 PM
xXxSilveradoxXx's Avatar
I've got Stranos/Konis and it's pretty much the same thing with me. The rear is just a little bit higher than the front.
Old 12-02-2009, 08:06 AM
LS1Tech Premium Sponsor
BMR Tech2's Avatar
If you decide to go with another spring i would like to give you another option. BMR springs have a front rate of 550lbs, a rear rate of 160lbs and will lower the car 1.25". Our springs also have a lifetime guarantee against spring sag. We plenty in stock and can ship them out the same day if you order by 3pm est. If you have any questions about our springs or any of BMR'S products please give me a call.
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Like us on Facebook!
Old 12-06-2009, 12:53 AM
gm02ceta's Avatar
That's a nice stance with the Strano/Koni set up.
Old 12-06-2009, 02:50 AM
Why thank you Sir!
Old 12-06-2009, 04:25 PM
LS1TECH Sponsor
Sam Strano's Avatar
Why thank you sir x2!
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
Old 12-06-2009, 06:10 PM
Engine_HP's Avatar
need to see pics of heater hose.
Old 12-08-2009, 10:39 AM
pjb
pjb's Avatar
I find that 1/2" heater hose fits best. a little spray lube helps it slide on easily.
Attached Thumbnails Will lowering springs even out the front/rear ride height?-springs.jpg
Old 12-08-2009, 12:02 PM
Engine_HP's Avatar
Originally Posted by pjb
I find that 1/2 heater hose fits best. a little spray lube helps it slide on easily.
thats what i thought.
thanks bro.
Quick Reply: Will lowering springs even out the front/rear ride height?
