Th400 or powerglide
Old 11-29-2009, 09:00 PM
johnLs1camaro's Avatar
Default Th400 or powerglide
Im building a vega, its a all out drag car, may see some street action once a month... I have a 600hp 5.3 turbo motor right now(first turbo build) Im wanting to try this out and then go with a bigger turbo and more nitrous in the future. This car will almost always only be used on the track, whats the benefits between the th400 and powerglide?
Old 11-30-2009, 02:11 PM
cambirdracing's Avatar
lite weight car, most drag strip use, I would go with the PG. TH400 takes more power to turn. Plus you can get SFI approved aftermarket cases for the PG, internal sheilds. Most 6 second top sportsman cars use them. If it was mostly street use, I would go with the TH400.
Old 12-01-2009, 06:39 AM
LS1Tech Sponsor
FTICONVERTERS's Avatar
The car should be light. A poerglde is definately the way to go. we deal with turbo cars making 2200 hp. Granted you are not there but a glide you can grow with.
Greg
__________________
FTI COMPETITION CONVERTERS AND TRANSMISSIONS
"IT'S NOT CHEATING, IT'S THE COMPETITIVE EDGE."
1-866-726-8358
info@ftiperformance.com
FTIPerformance.com
FTI Converter build sheet
Old 12-01-2009, 11:17 AM
^ awesome, looks like a glide is what im going with, thanks for the help.
Old 12-02-2009, 08:58 AM
1badzo's Avatar
Glide for sure
Old 12-02-2009, 04:33 PM
does this sound like a good price to you all. Built powerglide, trans brake,rebuilt 5200k stall. $1000
Old 12-06-2009, 10:14 PM
TJ
TJ's Avatar
is that scotty stites tranny for sale? he knows his stuff!
for what you are doing, PG all the way.
so many benefits for your application.
Old 12-06-2009, 10:29 PM
^ did he have a vega?
Old 12-07-2009, 11:37 AM
TJ
TJ's Avatar
he has had all kind of stuff. ill have to ask him.
mainly does built powerglides on the side.
i know he was doing a couple for 1000 hp and a couple aftermarket cases for 3000hp.
what you posted sounded like his for sale ad.
Old 12-07-2009, 11:52 AM
383lt1impala's Avatar
hughes sells a glide for a 1200hp for about 1200 bucks. best bang for the buck.
Old 12-07-2009, 11:17 PM
Idk, man I bought it from a guy out of cinci ohio.
Old 12-08-2009, 08:21 AM
TJ
TJ's Avatar
scotty is in MS. anyway... good luck with the swap.
lets here some results!
