putting in wheel studs and spacers. have a few q's first
Old 11-30-2009, 06:07 PM
twitchtwice's Avatar
Default putting in wheel studs and spacers. have a few q's first
I have some oem c5z06's and am going to install some spacers and studs so that i can get them to fit better in the rear in the wheel well. I have a few questions.
1. Will i need to pull the axles to successfully install the new wheel studs?
2. Will I need to buy new lug nuts after I put the new studs in even though I'm installing a spacer?
3. If you have or have know which spacer i should get please tell me. I'm torn between 1/4 and 7/16 spacers. I saw a picture of a camaro lowered with the same wheels with 7/16 spacers and like the stance.
Old 11-30-2009, 06:14 PM
94TRANS's Avatar
idk about spacers. but you do NOT have to pull the exles to install the new studs just take off the brakes and rotors and use a hammer to beat the old studs out. then you put the new studs in by using a nut that fits over the new stud loosely and then thread on the lugnut and use a impact gun to pull it all the way through. its quite easy acctually.
Old 11-30-2009, 06:21 PM
okay. i was worried that since they were longer they wouldnt not be able to be angled into the hub properly.
Old 11-30-2009, 06:25 PM
Tally TransAm's Avatar
if you have traction control, remove the wheel speed sensor and remove and install the studs through the hole for the sensor. if you dont have traction control you may have to pull the axles depending on how long they are
Old 11-30-2009, 06:34 PM
i do have traction control. thats a great idea. Thanks
Old 11-30-2009, 07:07 PM
reaperracer666's Avatar
7/16 is the correct spacer but alot of people use a 1/4 because thats all it needs
Old 11-30-2009, 07:52 PM
okay. so 7/16 is what will give the z06 wheel the flush look with the fender and the 1/4 is a tad less? thats what im understand from you post lol.
Old 11-30-2009, 08:17 PM
TORCHD 02 TA's Avatar
I am going to subscribe to this thread...
The reason is bc I am going to be buying some OE C6 wheels 18x10.5 in the back and those have a +56mm offset and I think I need to run a spacer? 1/4"? And if you run a spacer you want to run longer studs to?
Also where do you get longer, good quality studs from?
Old 11-30-2009, 08:51 PM
every thread i searched said that it would be a good idea to get better studs. I ordered my studs from ws6store.com because i just ordered a slp grill and figured id save on shipping. same studs they have at jegs and were the same price. they were part # 100-7708. the reason you want better studs is because 1. you will compromise the strength by making the distance between the wheel and the hub larger with the spacer and 2. with a spacer there will be less thread to screw the lug nut onto.
Old 11-30-2009, 08:59 PM
litch2004's Avatar
well i had to notch my brake caliper bracket to get the longer studs in. I just installed them about 5 minutes ago. I installed 3.25 ARP studs. I can take a picture for you as well as give you the ARP length if this is the size you need. These will work with factory acorn style. If you will be using closed end then you need to measure them out and make sure that you dont need the 2.5 inch instead.
Old 11-30-2009, 09:13 PM
NVR_SPDS's Avatar
When i installed my ARP studs (100-7708) i pulled the axles, its actually VERY easy to do.. And besides, it gives you a chance to check out the rear, and change the fluid while your there.
Remove brakes/rotors
Pop off cover
Remove bolt holding paddle, and pull it out.
push axles in, and take out c clips
pull out axles, and replace studs..
Then reverse the order.
Old 11-30-2009, 09:16 PM
litch2004's Avatar
Hey NVR SPDS Im guessing yours were the 2.5"? My part # was ARP-100-7713 and they were the 3.5"
Old 11-30-2009, 09:51 PM
NVR_SPDS's Avatar
Yup, i ran the 2.5s, because i was running widened WS.6 wheels, with a 1" adapter, and didnt want to cut the studs.. Suprisingly enough, the 2.5s fit inside the back of the wheel, so it was perfect.
Old 11-30-2009, 10:17 PM
yeah i ordered the 2.5"s. But if tally transam is correct i shouldnt need to remove the axles and just run the studs through the traction control sensor hole.
Old 11-30-2009, 10:26 PM
vatechguy3's Avatar
where are you getting your spacers from?
thanks
tony
Old 12-01-2009, 01:57 AM
litch2004's Avatar
That makes sense. Im running Greg Welds up front and will be running Race Star Industries in there rear (as soon as they get here next week). These pretty much already ahve a built in spacer not to mention the shank lug nuts.
Old 12-01-2009, 02:01 AM
litch2004's Avatar
If it doesnt work out for you here is another option before you go to pulling the axels:
Make a notch like so (i used a grinder and tiger disk)
The slide out the old ones and in with the new ones:
Old 12-01-2009, 06:59 AM
thanks
tony
i havent really decided yet. i can most likely find them at a local auto parts store but i was sure i couldnt get the arp studs from anywhere so i ordered those online.
litch:
thanks for the info. i may do that if i dont feel like pulling that axles.
Old 12-03-2009, 10:38 AM
alright, already ordered the arp studs.
i was wondering if Mr. Gasket 2372 from summits site is the correct spacer for the rear. i wanted the 7/16th, but im wondering if these spacers are the correct bolt pattern. im pretty sure they are, but i was just double checking before i ordered.
