Transmission Help 4L60e
My brothers transmission is playing out I believe. It has a broken transmission mount and it wont drive in neither D, but if we put it in 1 or 2 it will move. Is it the transmission, something to do with the rear end, or something else. Thanks
We believe it was a shift kit on it becuase it had a real nasty 1-2 shift that would chirp the tires and sometimes the 2-3 would also? Depending on whats wrong with it, would he need to get another shift kit or could he reuse the old one?
If you have it rebuilt, calm the 1-2 shift down as it will harm the input sprag. You may have to replace the seperater plate and install a new kit if some one made it too agressive, and the parts weren't sold with the car. After the rebuild, adjust the shifts with a tuning devise-mild for regular cruising. Firmer for WOT.
Good Luck.
Good Luck.
Good Luck.
Good Luck.
