Stereo & Electronics - Multiple cd's stuck in head unit
johnp94
12-01-2009, 03:43 PM
Hello everyone. Someone I know has multiple CD"s stuck in his stock gmc 2006 head unit. How can I get them out. Or how will a professional get them out. The head unit now reads no disk when I punch in a command. Thanks, John He said theres 4 in there but he also said that it was made to hold multiple cd's
00MaroVSix
12-01-2009, 08:55 PM
Someone I know has multiple CD"s stuck in his stock gmc 2006 head unit....unit now reads no disk when I punch in a command.
classic "my friend was wondering..." :mullet: haha just kidding bro. maybe a hard reset or something if thats possible might do the trick.
WhiteBird00
12-02-2009, 07:40 AM
Assuming that it is an in-dash 6 CD changer, does it still select the remaining discs and play them? If so, it is a simple matter of selecting the disc you want to eject before pressing the eject button. Simply pushing the eject button won't work unless there is a disc in the currently selected slot.
johnp94
12-02-2009, 01:03 PM
No doesn't play any cd. Just says no disc when I try to put a command or eject. Thanks, John
xxr98
12-04-2009, 04:11 PM
u may try this..i had a cd stuck in my stock cd player a few days ago and took another cd with the written side down (opposite of how u stick it in player normally) and put the tip of the cd at the very top of opening of cd player. the cd must be down at 45 degree angle (the play side will be pointed towards dome light) and insert slowly, then lift up the cd where it is flat, it should kick out the cd. Make sure u dont put the cd more than 1/4 of the way in.
Also, make sure u hold onto the cd!!! lol
hope it helps
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
