gm asa cam
Old 12-01-2009, 04:42 PM
themack56's Avatar
Exclamation gm asa cam
anybody got tune file for hptuners. having trouble getting my car to stay on in D or R. park is fine but when i put it in D the idle goes down alot and wants to die. same with R. another issue is when im stopped. and i step on the gas a bit in D and it accelerates a bit then i let off right away, the idle goes all the way down and it struggles to stay alive. mods below in sig
tranny is a4 with ss3600yank.
Old 12-01-2009, 05:47 PM
VortecHOjunkie's Avatar
Go to your VE table and multiply the 400 to 800 rows by 75% (I usually do the 1200 row about 85% as well). Then go to your base running airflow and multiply those by prolly 150%. That should help you out.
Old 12-01-2009, 07:13 PM
themack56's Avatar
this seems to happen more when the car is warm, at operating temp.
Old 12-01-2009, 07:24 PM
Its running open loop when its cold. When it transitions (warms up) into closed loop you will notice it surging more. Try the above recommendations. Should help you out.
Old 12-01-2009, 07:37 PM
themack56's Avatar
ok thanks
