what does everyone think of 4.10 gears and stall converter
Old 12-01-2009, 06:12 PM
Big Red Z28's Avatar
Default what does everyone think of 4.10 gears and stall converter
I am switching to a built auto from FLT or Performabuilt. I currently have a T-56 my rear gear is 4.10, This will be a daily driver with the goal of a fast street car. My setup up is heads, cam, exhaust, other boltons, using drag radials. Should i switch gears?
Old 12-01-2009, 06:17 PM
Sorry if this is the wrong thread, Mods please delete if so.
Old 12-01-2009, 06:18 PM
blackhawk0251's Avatar
Id say if you were mainly racing then 4.10s would be perfect, but since you want it to be a street car I would lean more towards the 3.73's. This is the right thread.
Old 12-01-2009, 06:47 PM
Another questions is if i stay with the 4.10 versus 3.73 what will my rpm and driveability be like? And How much will this affect my top end beyond the quarter mile? Every once in a while i get those guys that wont give up and it takes a good mile to prove it. I know the 3.73 will be better for top end speed but by how much?
Old 12-01-2009, 11:06 PM
I would say it could net you around 34ish mph, if were talking about ***** to the wall, all out top speed.
Old 12-02-2009, 06:31 AM
DannoWS6's Avatar
A daily driver street car. I would advise against 4.10's. It will suck on the hwy. And yes your top end will suffer, but it will suffer anyways going to the A4.
Old 12-02-2009, 06:53 AM
99FormulaM6's Avatar
I have 4.10s and a 3200 Circle D stall and on the highway at 80 im at like 3000 rpms or so. I bought the car with them in it, but I plan on swapping them out in the future.
However, I still managed to get 17-18 mpg on the highway with those gears and im cam/stall/bolt ons
Old 12-02-2009, 02:12 PM
382ssz28's Avatar
I LOVE my 4.10's! I shift at 7000RPM. I get 25MPG and have had the car well in excess of 150MPH with more to go. I drive from Traverse City to Detroit and back for the Woodward and Telegragh Cruises-270 miles one way. Also, the Grand Rapids Cruise, about 120 miles one way. My motor is built for higher rpm's. The diff ratio is part of the "Total Package", so to speak. Your diff ratio should be chosen based on lots of criteria: Heads, cam, intake, hedders, compression, trans and converter, etc. If your car is mostly stock with minor bolt-ons, 3.42-3.73's are great. If you are going to play, the 4.10's are awesome. With the car and trans properly tuned, it will feel like it came from the factory. Since you already have the gears, try them out for a while. If you don't like them, go to the 3.73's.
PS,
I should add I run 28" tires. That will have to be taken into consideration.
Good Luck!
Old 12-02-2009, 10:27 PM
Paul57's Avatar
The formula is MPH x drive ratio x 336 / tire diameter x overdrive (.7) = RPM
4.10 @ 60 w/ 27" tire = 2143 RPM
4.10 @ 70 w/ 27" tire = 2500 RPM
3.73 @ 60 w/ 27" tire = 1950 RPM
Old 12-02-2009, 11:23 PM
AutomagicLS1's Avatar
I had 4.11's with a 26" tire (not recommended) and a 28" tire. with the 28" tire at 70 it turns about 2400 I think. 26" tire was horrid
Old 12-03-2009, 07:16 AM
DannoWS6's Avatar
remember this is his daily driver street car and i would assume would stay with 26" tires. With that said I could not honestly recommend a 4.10 gearset.
Old 12-03-2009, 05:30 PM
Yes DannoWs6 is correct. This is 90% street car with a current nitto drag
17/40/275 tire if i remember it is a 26" tire. If i take it to the track it will be just for fun to see what i can do.
Old 12-04-2009, 06:25 AM
DannoWS6's Avatar
A good option to consider is to sell your rear and pick up a stock M6 rear with 3.42's. (or swap) It would be cheap and 3.42's work excellent in the A4. Get a nice 3600-4000 torque converter and keep the gearing streetable and you will be much happier.
Old 12-04-2009, 12:48 PM
Dom
Dom's Avatar
Stock tires are 25.6".
I daily drove 4.10s and 4200 stall. It's not bad unless you want to go 80 on the highway for a long time. That equaled 3000 RPM and I didn't like it.
With 4.10s and stock tires you'll be at 2448 RPM @ 65mph. That's not too bad. Right now my 3.23s do 1929 RPM @ 65mph. That's good for long highway drives. I have 4 miles to work and I use the highway for an hour on the weekend so I could get 4.10s again and it wouldn't be a big deal. If I had an hour commute to work on the highway then 4.10s would be too much. It also depends on tire height. If at some point you'll get 28" tires then you might want to step it up with gears. Are you still on the 10 bolt? If you have a manual, forget 4.10s and drag radials. You will strip the pinion teeth first time at the track.
Old 12-04-2009, 01:22 PM
FASTEDDIE Z's Avatar
I have 373's and a stock stall on 245 50 16 's .My car runs @ 2400 rpm at 65 mph . 410's are ok if your at the track all the time .On street mostly ?? Nahh ,stick with 342's or 373's and a nice converter (3600- 4000). It will come out of the hole very nicely .
Old 12-04-2009, 06:47 PM
Thanks guys for the input. DannoWS6 my Z28 is currently an M6 and i still have the factory 3.42 gears in the garage. I think i will play with the 4.10 that are currently in the rear and if i dont like it i will throw the 3.42 back in. Unless any one thinks this will have an impact on the stall converter stall and str ratio.
Old 12-04-2009, 07:06 PM
silverz28camaro's Avatar
a 4,000 stall and the 3.42's will be a great street combo, awesome hole shot ability,and it will have the top end gearing with 26in tires.
I run 3.73's and a 3600 converter, love it, but I may try the ss4000 next time tranny needs gone through.
Old 12-05-2009, 02:10 PM
Black99CamaroSS's Avatar
I would think it depends on his cam and converter selection. I see no problem with a 3600-4000 stall and 4.10 gears. The gears make a high stall converter much more streetable.
Old 12-05-2009, 06:50 PM
southpaw0314's Avatar
gas mileage is going to suck with an a4. engine rpms are going to increase significantly on the highway compared to the m6.
Old 12-05-2009, 07:17 PM
SnIpEz's Avatar
4.10 gears will make you get up and go, but you'll hate the highway
Quick Reply: what does everyone think of 4.10 gears and stall converter
