Did my thermostat stick?
Old 12-01-2009, 07:29 PM
TurdsOfMayhem's Avatar
Default Did my thermostat stick?
Driving home from the park and ride, its about 45-50 degrees outside. Well, sitting in a nice bit of traffic, patiently waiting to get home. Like I always do, I check my guages frequently, everything good. Inch forward as people always do. Look down, and see my temp guage jump from just before 210 to the first line past 210, I instantly thought "WTF?!" So I watched it a few more seconds and it kept creeping higher, I quickly turned the heater on full blast, and had my hand on the key ready to kill the engine. Then in 2-3 movements, went back to 210 and stayed there the rest of the way home.
I had never experienced something like this, so it was my first assumption. I had a coolant flush 13 months ago, so coolant should still be just fine.
Any other thoughts? Is it difficult to replace the thermostat?
Old 12-01-2009, 07:35 PM
ae13291's Avatar
try to replace the thermostat, it is not difficult at all, you will just loose some coolent that all. its held on by 2 10mm bolts.
Old 12-01-2009, 07:38 PM
Assuming you believe my assumption was right?
Old 12-01-2009, 07:42 PM
LS6427's Avatar
Any time you temp guage "jumps" up and down, its almost certainly a failing coolant temp sensor.
If your t-stat was stuck closed your temp guage would not stop until it went into the red once it started to move. Nothing your heater is gonna do to stop it once that snowball starts rolling.
Also, when you are overheating the temp needle moves slowly and steadily, it sweeps, they don't jump up and down quickly.
Old 12-01-2009, 07:43 PM
ae13291's Avatar
the internal of the thermastat is a type of elastic compound that expands when it reaches a certain temprature, and when a thermostat gets old enough that elastic compound can find its way out and then the thermostat wont open up or it would partially open up. so in your case its maybe not opening up all the way, it took a higher temp for it to open. so yes your assumption is correct.
Old 12-01-2009, 07:45 PM
ae13291's Avatar
like said above thats also a possibility the temprature sensor, these ls1 cars temp guages arent so acurate either. try out the thermostat first tho
Old 12-01-2009, 07:50 PM
Thanks for the information.
Old 12-01-2009, 07:52 PM
ae13291's Avatar
sure thing man goodluck. the t stats on these cars are like $40
Old 12-01-2009, 07:56 PM
Just looked at autozone the 'oem' replacement is 19.99 and the 160 thermo 29.99. So not to bad at all. Coolant temp sensors don't seem to be to expensive either. Since I have an '01, is mine located on the front of the drivers side head?
Old 12-01-2009, 08:03 PM
ae13291's Avatar
yea thats a good deal. also buy the cheaper value craft product from autozone, and you will be surprised to open the box and find out its a oem motorad thermostat the same one that comes with the car and its made in Germany
Old 12-01-2009, 08:06 PM
Hmmm, online just shows durlast. Think they might have them in store and they are just not listed online?
Old 12-01-2009, 08:09 PM
ae13291's Avatar
yea i dont see it online either, maybe they switched the names and the duralast could be the one
