pros/cons of stiffer rear shocks
Old 12-02-2009, 11:57 AM
teke184's Avatar
Default pros/cons of stiffer rear shocks
other than obvious ride harshness....
what disadvantage do stiffer rear shocks have?
trying to minimize bottoming out on rougher roads now that i'm lowered. there are a few dips (after coming off a bridge) that i've head a slight scrape on.
if i'm not mistaken i'm 1 turn from full soft on my Konis.
Old 12-02-2009, 12:46 PM
LS1TECH Sponsor
Sam Strano's Avatar
Koni's SA's don't adjust compression, just rebound. Rebound is the extension of the shock and will do nothing to keep the car from compressing the same way it does. That's a spring rate/compression damping thing.
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
Old 12-02-2009, 12:50 PM
teke184's Avatar
gotcha....kindda thought that...but wasn't sure.
Old 12-02-2009, 01:21 PM
z28bryan's Avatar
Ride harshness is always subjective to ones own opinion. Ideally you want a good compression setting to handle your unsprung weight. Too much can make the shocks cause a harsh ride. Too little could cause you to impact full suspension travel too hard causing a harsh ride. Unless you have koni DA's or KYB's then you probably can't adjust compression
Quick Reply: pros/cons of stiffer rear shocks
