good heads/cam...Cam?
What is *THE* Cam now for heads/cam combos... Putting a 6.0l into a 3rd gen, wanting to do a heads cam combo, going to put the edelbrock super victor intake on it with a quick fuel carb..Have a built th350 behind it, want to make good HP obviously but still needs to be streetable...
Suggestions?
Suggestions?
Alot more info about your setup will be needed but I would suggest giving Futral Motorsports a call and get them to fix you up with a combo. Great products with proven performance. http://www.futralmotorsports.com/fms...asp?pf=3&pg=29
rotating assembly will be stock, other than just putting new bearings and stuff in it... its a 6.0l take out from a truck...Im going to put a good oil pump and timing chain in it, new lifters, I wanna put a bad *** thumper in it. I was thinking of just getting a good set of GM heads and porting and polishing them putting good parts in them, then tossing the edelbrock super victor on it with a quick fuel carb and the MSD ignition...
its a pretty much full weight 3rd gen, gunna have a Moser 12 bolt with 4.10 gear....Alston rear suspension, qa1 shocks...
thanks for any suggestions.
