TCI flex plate or Stock flexplate?
im about to drop my motor in my ride but i wana upgrade some things since its out i was planing on buying a tci flex plate and a SLP harmonic balancer is the flex plate worth the money or should i use the stock one ..........any other upgrade tips i have a 00 ls1 5.7
i was planing on using the stock converter put if i can upgrade its alway helpful i dont know the diff gear ratio yet i was planing on geting a rear end from a grand national with a posi or a 12 bolt with a posi
well i bought the engine and was going to install it in my el co in about two weeks or less but before i drop it im i wanted to upgrade some parts over stock after i get it runing i will do cam and head swap
im planing on doing both mainly street there is a lighting that thinks he can beat anyone and some ricers so im planing on showing a real cars power. should i use the stock converter or upgrade and if so to which
I got this one also, Its manufactured by CAT Power Systems. It is significantly thicker then stock and much stronger Im willing to bet. It does have the SFI rating also. I got mine for about $70 shipped I believe.
