How to retard timing?
I know the concept and how it works, and why I need it, I just want to learn how by which means or tools can I retard timing?
Is it true that you can retard time using cam gears? and a tuner? or are they different timing conepts? I believe they help each other not the same concept though...
corret me please
corret me please
Best way to do it is using a tuning software. Some of the nitrous places sell timing tuners but they are limited to only a few degrees of retard on the stock tune. Do you want to do it for nitrous use?
LS1Tech Premium Sponsor
The cam and crank gears can adjust the cam timing, but to adjust ignition timing you must use one of those boxes to fool the PCM or have the PCM tuned to adjust the timing advance.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
no I ment just for general knowledge... not that I want to retard timing when I'm stock... I'm tryin to learn methods only guys... chill out
and thanks for the advices... I told you I know the concept and all... its just that I've never done it, and since I know the concept I don't think its cool to have stock car retarded in timing... hehehe
